I have a 42" Craftsman mower 12 years old. It has the hydrostatic type drive where the more you move the shift lever either direction, the faster you go. The transmission has always been a bit noisy in reverse, but worked. This spring it does not want to allow me to push the mower into or out of the garage when I release the lever in the back. Almost seems like the brake is on. It does drive okay under power, but a bit more noisy and slower than ussual. Any ideas? Is there fluid in the drive that I should check and change?
Any help is appreciated.
