Hi,
I recently bought a Craftsman 917.270610 "as is", and I think the guy had done something to mask a problem with the drive belt.
It worked the first 2 times I mowed my 1/2 acre yard, then the drive belt slipped off. Since then, it will run for between 30 seconds and 2 minutes before slipping off again.
I can take my finger and slip the belt back on, start it back up and mow for 30 seconds or so then it slips off again.
The clutching idler pulley is really loose...I can move it back and forth a little, and can "tilt" it about 25 degrees. Is that the expected behavior? I checked the clutch idler spring, thinking it had fallen off, but it's there.
Any ideas? I'm new to lawn mower repair, so I don't want to spend my whole Saturday replacing the belt and spring only to find out that wasn't the problem in the first place...
