Sears/Craftsman
Model: 316.794970 REV P00
Item: 41AS320G799
It looks like it cross-references to a Troy-Bilt TB320BV
Does anyone know what series engine this is and where I can find the service manual (or do these smaller 2-cycles not have service manuals, unlike the B&S I have worked on and was able to find easily)?
Long story:
Questions:
Item: 41AS320G799
Craftsman 2 Cycle Mulching Blower Vacuum 316.794970 - 41AS320G799 | MTD Parts
Find parts and product manuals for your Craftsman 2 Cycle Mulching Blower Vacuum 316.794970. Free shipping on parts orders over $45.
www.mtdparts.com
Long story:
- Pull-start mechanism went bad. Took the blower apart, and tried to repair it, but it failed again.
- Couldn't find the part (NLA) at the time, so it went into a storage box.
- PIcked project back up many years later. Found/ordered a complete replacement pull-start mechanism. Installed it. Seemed like it failed again immediately.
- I thought the new pull-start mech went bad, so I set the project aside (got an EGO to replace it but now want to have a leaf vacuum of sorts).
- Took it apart again and realized that I forgot to transfer the shaft spacer from the old pull start assembly given the failure was that the flywheel with integrated woodruff key sheared the key...
- I have a new flywheel on the way ($15) but before I put this back together, once and for all...
Questions:
- Torque value is for the crankshaft extension nut that the impeller bolts to
- Torque for the impeller bolt
- Loctite?
