CraftsmanFlaws
First, the good news. I finally got a higher level manager to replace my tractor that I had multiple issues with, with a brand new one! I had it delivered in the crate, as the incompetents in Warehouse & Delivery ALWAYS scratch and do damage to the units when they unpack and handle them.
It was as near perfect as one could expect. The B&S Intek Platinum 19hp sounded quieter than on the old unit.
Now, the bad part: Upon starting it up, I was upset to find that the Hydro Gear T2 transmission has a whine in reverse, which the other identical unit did not have. It also moves slowly forward in neutral. I had this problem, to a lesser extent, in the old tractor, but the tech had to make an adjustment to correct this 3 times before getting it to be totally stationary in Neutral, so that issue should be solveable. Though I find it odd that this unit actually moves, not just creeps, forward in neutral. It's not that it is moving fast, but it is not just creeping forward as the other one did. How much is this related to the tranny as opposed to the linkage?
I have read that this sometimes can lessen or disappear, though that sounds bogus to me.
Who knows about this transmission? I know this is a lower-end Hydrostatic, though I was told that it will last a long time if you use it properly to cut your lawn, and nothing else.
I have the choice to either have them replace it with another one within 30 days; or have their tech analyze if it needs a new transmission, and order and replace it if that is his finding.
However, from my experience with Sears (& thousands of horror stories plastered on tractor & other sites all over the internet, even Sears own website forums, they basically don't respect or treat their customers, so I don't trust them.
Their past techs have done damage, such as carelessly scraping the bottom of the deck (failing to lift it to its top position) across my garage floor and then over a very rough apron, and then Sears refused to do anything, stating that is "cosmetic" and not covered. Without going into more of the games Sears plays, suffice it to say that I fear either choice, as getting even a newly-crated one, the manufacturer, Husqvarna, is variable in their QC and the painting and assembly of the tractors. On the other hand, I don't know if I can trust the tech, and if a replacement of the transmission will end up scratching up the unit, though I would have the one tech who has been the most careful do any work the tractor needs.
Your knowledge and suggestions much appreciated.
:confused2:
