Does anyone know about these Kohler 19.5 engines? I have a craftsman 46 inch riding lawn mower with the aforementioned engine. I get everything cleaned up so that I have spark then it will backfire and start to run. For a bout three minutes then dies and wont start. I check for spark and there is no spark. So then I clean on the coil and the flywheel and will have spark again. So I start it and we go through the same thing all over again. Also there is ,when its running , gas splashing up from the carburetor at times. Does anyone have any ideas why the spark keeps quitting or why there would be gas splashing out the carb? Thanks for any help or suggestions......:ashamed:
