The float bowl on my carb isn't getting fuel. I get gas up to the fuel pump. but not into the float bowl. I've replaced the diaphram. I fill the float bowl up and it runs perfect after it uses the gas it just dies again. WHAT IS GOING ON!?
Without looking at the parts lookup, I am assuming this the engine with the fuel pump mounted on the front of the carb. Is so, remove the top of the carb, and crank the engine and see if the fuel pump is actually pumping fuel. If it is pumping then there is a blockage between the pump, through the fuel passage, and the needle valve.
