Craftsman 15hp Kohler
reeeed
Craftsman 15hp Kohler dies out when on a hill. Please help me diagnose this problem . Thanks
reddragon
does it die immediately or does it sputter and then die?
reeeed
The engine sputters out and when I put it back on level ground it fires back up. The tank is full of gas and I checked the fuel line and there is no blockage.
THANKS !
reddragon
its starving for fuel.....probably a low float level...try adjusting the float a little high and see if it improves.........give us the engine model/serial numbers and we can check what adjustments can be done:smile:
