Export thread
craftsman 12hp briggs and Stratton
#1
liljohn
liljohn
Well i did a servicing on my mower new oil new spark plug new battery cable. Because i was mowing and my mower just started dying and i would stop the blades from running and push in clutch brake and it would stay running a little bit but if i lower throttle it would dye and if i kept mowing it would die i need to get it fixed any ideas?
#2
liljohn
liljohn
Anyone
#3
Carscw
Carscw
Could be the gas cap vent.
How long after it shuts off do you have to wait before it will start again?
#4
liljohn
liljohn
Not long after how can i fix the gas camp vent it runs good when it runs just all of a sudden dies
#5
Carscw
Carscw
When it starts to act up take the gas cap off. If it starts running good. You can clean the vent hole or get a new cap.
If it still stalls out then we can go from there.
#6
liljohn
liljohn
Ok i will do that tomorrow thanks ill get back to you
#7
liljohn
liljohn
So its not fuel cap it starts then dies aafter 30 secs of idle
#8
liljohn
liljohn
I tried adjusting carburetor but not working at all im stuck i really need ro know how to fix this
#9
liljohn
liljohn
Pls help
#10
Fish
Fish
First, let us know your engine's model numbers, also go ahead and put up the tractor's model numbers.
#11
liljohn
liljohn
#12
Fish
Fish
No, the tractor number won't give me any engine info. Go ahead and remove the hood and take some pics of the engine, the numbers should be near the spark plug.
#13
liljohn
liljohn
#14
liljohn
liljohn
Any update need to fix this
#15
liljohn
liljohn
? Any help pls
#16
Carscw
Carscw
Check the fuel filter and lines.
Make sure the gas is getting to the carb.
Take the fuel line off the carb and see how fast the gas comes out the line. Should come out a steady stream.
#17
J
jimmy3262
Take the air cleaner off and when it starts dieing shoot starting fluid down the intake to make sure its starving for fuel. If it is I would check the float to make sure it is moving freely and also make sure the float needle is moving freely
