I put a new drive belt on after old one broke. Now it will barely move,like the belt is slipping and I can't move the shift lever while engine is running. I made a clutch linkage adjustment but it didn't help. I did notice that the drive belt was moving with the shift lever in neutral and clutch depressed. According to the manual the belt is suppose to stop with clutch pedal depressed and shift lever in neutral. Any suggestions ?
