when i use brake it hangs and i have to pull back with my toe to release. thanks for any help.
R rtaven Forum Newbie Joined Mar 5, 2013 Threads 1 Messages 1 Mar 5, 2013 / craftman 46" brake hangs #1 when i use brake it hangs and i have to pull back with my toe to release. thanks for any help.
Kodie's Lawn Service Well-Known Member Joined Dec 27, 2012 Threads 96 Messages 705 Mar 5, 2013 / craftman 46" brake hangs #2 i the spring bhinde the tire on your trany maybe broken pull of the tire its normally the right side when sitting on the mower and the spring on the rod maybe broken hope this helps :wink::thumbsup::smile:
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,812 Mar 5, 2013 / craftman 46" brake hangs #3 If you post the model numbers we should be able to help you locate the broken or missing return spring.
wjjones , Joined May 29, 2011 Threads 50 Messages 1,456 Mar 6, 2013 / craftman 46" brake hangs #4 If its out of adjustment the spring wont help it return, or release the brake. Or as mentioned the spring has broken off, and gone.
