coversion
qmark
Conversion gas to diesel
Hi,
I own a grasshopper 725 G2. I am considering changing to a diesel engine. What model of Kubota diesel was used on these?
thanks
mark
173abn
on my 928d the model #isD1105...order # is 724059...russ
BlazNT
Just keep in mind you will need a lot more stuff for a diesel swap. New wiring harness. A new engine mounting plate. Possible to also need some pulleys changed to fit the new setup. A new PTO as well.
