Q qmark Active Member Joined Apr 16, 2017 Messages 55 Apr 16, 2017 #1 Conversion gas to diesel Hi, I own a grasshopper 725 G2. I am considering changing to a diesel engine. What model of Kubota diesel was used on these? thanks mark Last edited: Apr 16, 2017
173abn Well-Known Member Joined May 7, 2010 Messages 869 Apr 16, 2017 #2 on my 928d the model #isD1105...order # is 724059...russ
Q qmark Active Member Joined Apr 16, 2017 Messages 55 Apr 17, 2017 #3 173abn said: on my 928d the model #isD1105...order # is 724059...russ Click to expand... Thanks for the reply.
BlazNT Lawn Pro Joined Apr 26, 2012 Messages 6,973 Apr 18, 2017 #4 Just keep in mind you will need a lot more stuff for a diesel swap. New wiring harness. A new engine mounting plate. Possible to also need some pulleys changed to fit the new setup. A new PTO as well.
