PTmowerMech
- Apr 16, 2018
- 424
- 3,245
I've got a customer who brought me one with a cracked block. In that same top corner as they all crack. And for the same reason. Loose top cover bolts. I've ever made this repair, so I told him I wouldn't try it. But, I did take a small grinder and cleaned off most of the old repair that someone tried. BTW, one of the reasons I didn't do the repair is because there's still some of the stuff they used the first time, down in the crack, that you can't reach.
With that said, I got some stupid ad on my facebook feed, that showed a guy heating up aluminum and melting some sort of metal onto it. And like all ads, it worked like a charm. So I took to Youtube to check their reviews. I found a few people who knew welding/soldering and they tested it on several different types of metal. On most of the metal, it didn't work. But every video I watched, where they did this to aluminum, it did work. And worked well.
Here's the ad: (turn your volume down)
Here's one of the reviews I watched.
