Courage 20HP running extremely loud, some popping
ozpkchris
Fairly new to working on these type of engines, any direction would be greatly appreciated.
2007 SV600s in a troyB Bronco.
Mower sat for 6 months. would not start.
New spark plug, oil/filter, air filter, fuel filter, new gas, in tank carb cleaner.
Starts and cuts- but the system is running extremely loud, has some popping, occasional stall after start. mower gets louder with blades engaged.
I noticed fuel filter us not full when running engine. Engine runs hot.
I am not sure what to trouble shoot? thinking of ordering new carb for $30.
Thanks for the advise.
I ordered and received the head gasket repair kit. I will give it a go this weekend. The cost was $28.
I’ll check the gap on the rocker while it’s open.
I did order a entire new carb from amazon for $25. Not sure if I will put it in yet.
Should I drain the oil before opening it up?
