I used to have an 1989 Excel Hustler 440 and something always needed maintenance or fixing on it. I now have the Country Clipper Boss (2010) 60" w/ Kawasaki 26hp and love it. No problems, easy low maintenance, nothing breaks, and it looks great. Check the oil, fill it with gas and go. I really like the "BOSS" name and now they have dropped it. Bad move Country Clipper!! I have the joy stick control and love it. The deck power tilts allowing easy blade changes and cleaning the underside. I sit on a stool to change the blades instead of laying on the ground or rigging a lift of some sort. The blades get sharpened and changed more often because of this and it gives a better cut. Compressed air is used to blow off the mower after use and I only occasionally wash it off. I removed the pulley guards from the deck and remounted them with magnets so I could remove them and blow off around the pulleys easier. This works great if you like to keep your mower clean and you don't have to put it away wet with the compressed air. I also installed flat proof semi pneumatic dolly wheels.
However if I had to do it over again, I would have gotten the 72" cut with more HP. I don't believe you can have too big of a mower. Occasionally I double cut to the popular X pattern and my lawn looks exceptional. With a wider cut you can do this in the same time a smaller mower takes to cut one pass. And if I'm in a hurry I can single pass it before dinner gets cold....or the beer gets warm...which ever. I'm cutting about 3 acres with the Clipper and use a Kubota tractor 72" cut w/ 45hp for another 3 acres or so about once a month. We have 10 acres total.
Bill - Northwest IN
