Can y’all tell me where the coolant drain plug is on John Deere 345 FD590V
A Andy C. Forum Newbie Joined Jun 8, 2021 Threads 2 Messages 5 May 6, 2023 / Coolant drain JD 345 #1 Can y’all tell me where the coolant drain plug is on John Deere 345 FD590V
StarTech Lawn Royalty Joined Feb 19, 2020 Threads 80 Messages 10,304 May 7, 2023 / Coolant drain JD 345 #2 There not one. You remove the coolant bypass hose off the pump and put the hose to a drain pan quickly.
B boatmoter Member Joined May 6, 2023 Threads 0 Messages 45 May 7, 2023 / Coolant drain JD 345 #3 Andy C. said: Can y’all tell me where the coolant drain plug is on John Deere 345 FD590V Click to expand... I have the same engine on my John Deere 320. mine does not have a petcock for a drain.
