luckydevil
- Apr 15, 2016
- 2
- 5
I have a 10 hp B&S generator that I'm converting to electric start. I've checked to make sure the engine has mounting holes for the starter. No problem. The flywheel has mounting holes for a ring gear. I'd also like to install an alternator at the same time for charging the battery. My flywheel doesn't have alternator magnets. My engine model number is 19E412 Type 0131-01 Code 9611021A Briggs parts breakdown doesn't show a flywheel with magnets. The flywheel part number that's currently on my machine is 690615. After doing a lot of research it appears B&S is like a lot of other manufacturers and used the same mold to make a lot of different part numbers depending on the use. I've found a part that appears might fit my motor but was made for a Toro or some other application. The only difference appearing to be this one has alternator magnets. The flywheel in question is part number 391983. Can anyone tell me if they have knowledge this will work or not?
And yes, I realize that I could use a trickle charger instead of adding an alternator.
