Skippydiesel
- Nov 29, 2020
- 521
I am but an old farmer, limited understanding, just accept the recommendations of what seems rational.I am a fan of propane as autogas fuel. Curious about your oil change interval statement, if it comes out looking clean and not smelling burnt (assumption). How are you know the oil needs changed at same intervals? Is there any data from oil sample tests (Blackstone Labs, or similar) that prove out the same oil change interval is true for gasoline and propane fuels? I am of the understanding propane burns cleaner, I would think that the oil would contaminate more slowly. Does the oil just wear out at a certain rate with no other factors?
Modern crankcase oils containe many additives, to help them performer to the standards the engineers/chemists demand.
When the oil is fresh, the mix is in balance & contains no foreign contaminants.
Subject the oil to;
- Heating & cooling cycles
- Byproducts of combustion
- Unburnt fuel
- Moisture
- Pressure
- Oxidisation
- Metal particles in suspension
- Atmospheric dust
The oils ability to keep metal components apart will be reduced. Eventually the engine will experince accelerated wear.
My understanding is that used oil can be recycled, that is cleaned, new additives mixed and the oil can be used again.
It seems to me that no matter the fuel type, burnt in the engine, at some stage the crankcase oil should be replaced, no matter how clean/dirty it may look.
