connecting rod torque spec
markfavale
Hi Guys-
The manual I found on line for my Kohler Command 12.5 hp ending shows 2 different torque settings - one for a 6 mm bolt and another for an 8 mm bolt. My bolt is a 10 mm. Unless they are talking about the width of the bolt (not the size of the socket) in which case mine is 7mm. Am I missing something?
Thanks in advance-
mark
Does it say 6mm or M6 or 8mm or M8?
I know in my KAWASAKI manual, it lists bolts by the bolt diameter not head size. M6 bolt was 10mm
Give us the model number and we'll see if we can find out something for you.
The manual says the 2 bolt size options are 6mm and 8mm.
The mower is a Kohler Command CV 12.5 and I think the spec # is 1252.
Thanks a ton, guys.
Mark
