Engine Confused about Engine Oil
luvatenor
I have an exmark Z -72" with a Kubota Diesel engine. Exmark advises that I use Mobil 1 15W50 synthetic oil in both the engine and Hydraulic system. I went to a Kubota dealer for an oil filter and he advised me that Kubota recommends their 15w40 engine oil(not synthetic) in all of their engines. Any thoughts?
Found this in another forum I am a member of and thought it might help. FYI, we do sell Kubota's. You'll have to make your own decision.
Kubota does \"not recognize synthetic oil\"
Just when I thought I had it all figured out.....
Meaning I believe the synthetic oil is superior to conventional oil, especially here in the north-east. But I have just completed my 50 hour fluid change on my B2710 and used Shell 15w40 Rotella in the engine and super UDT in the back. (clean screen by the way. NO metal.)
First, it was my dealer who said, "Just use good quality 15w40 diesel oil. Synthetic will void the Kubota warranty".
Next I called Kutoba Tractor Corp in Torrance, CA, Warranty Dept. They said (sounding a bit like a legal mumbo-jumbo answer), "Use what is stated in the manual. We cannot guarantee that the warranty will cover synthetic motor oil". I mentioned that the manual also says to use 10w30, but EVERY DEALER uses 15w40 (ok Bird, stop smiling, you were right and I was wrong). They had no response.
Lastly I called a mechanic worker-guy at Kubota Tractor Corp in columbus, OH. He was pretty knowledgeable but held the party line. He said, "Use a regular good quality 15w40 diesel oil. Kubota does not recognize synthetic oil". He also said that he thinks Kubota oil is 15w40 Valvoline and was in my tractor from the factory. I asked why my manual said to use 10w30 and he sorta danced around a bit. I think he said, "most commonly available oils in the US are straight 30 and 10-30 multi-vis. That may be why the Japanese company put that in the manual. (I know, we have discussed this before... but we do love oil discussions!) Also, never mind the discrepancy that Super UDT "may" be partially synthetic.
So, in the future, I believe Kubota may actually approve synthetic motor oil for use. Its better oil. But until they do, I'm going to use the old-technology stuff because, god forbid, I had a major engine failure and oil analysis indicated that I had a synthetic oil in there and my warranty was voided. This is too big an issue for the little guy to fight. I may email this discussion to Exxon-Mobil corp and Amsoil, etc. I think it would be in their interest to work with Kubota and other companies who have not yet gotten around to thinking about synthetic oils.
luvatenor
Thank you very much for your informed response-My Kubota dealer said that the Kubota 15w40 oil recommended by Kubota has synthetic oil in it-Now I am more confused than before-
I'll try to remember to talk to my boss and/or Kubota rep next week to see what I can find out. We are a small Kubota dealer and my boss has been selling them for over 20 years. I'll give you my opinion at that time, because I know what we do and I do not always agree with the Kubota policy. Remnd me next week if you don't hear from me.
luvatenor
Hi-just reminding you-did you have a chance to speak to your boss about the engine oil?-thanks
Sorry, I forgot. Try to remember tomorrow.
Here is the answer I got when I asked Kubota support if I can use synthetic oil in my Kubota.
A: Kubota recommends oil with an API rating of CF or higher. If the synthetic oil meets those standards, it can be used in Kubota engines.
Hope this helps.
