Compression problem?
diesel
I recently bought 2 older simplicity lawn mowers(made by alice and chamers) both 11 hp, the difference is one is hydrostatic one is manual. on the manual one i rebuilt the carb, gave it a new fuel filter, added some oil, tuned the carb, adjusted the choke, drained fuel tank and gave it new gas, gave ot a lil seafoam and gave it a new sparkplug. Ran great. As for the hydrostatic did the same ****, carb flooded, replaced the float made sure the needle valve port was clean and stopped the flooding. it starts every now and then by luck. but it barely runs over 2 minutes before shutting off. it has great spark, and is getting fresh gas, so is it losing compression from somewhere? i removed the head and the gasket didnt look too bad minor wear on the inside part of the gasket. idk what else it could be, also when i excessivly try to start it the carb backfire smoke from the intake. please help thanks.:frown:
Carscw
Don't know the answer but will help move this to the top for you
(( racing is the only sport that you need two balls ))
Might be an intermittent spark problem. Are those engines old enough to have points, If it does may try replacing the points and condensor.
chance123
You suspect a compression problem. Have you taken a compression reading?
