Is a compression tester really neccessary? Ifso what mm threads for most small engine needs?
C cjdave Member Joined Apr 7, 2012 Threads 18 Messages 48 May 19, 2012 / Comperession Tester #1 Is a compression tester really neccessary? Ifso what mm threads for most small engine needs?
WISCOPROUD Active Member Joined May 19, 2012 Threads 0 Messages 70 May 20, 2012 / Comperession Tester #2 its a good diagnostic tool for pointing u in a direction Last edited: May 20, 2012
ILENGINE Lawn Royalty Joined May 6, 2010 Threads 51 Messages 11,252 May 20, 2012 / Comperession Tester #3 It is a good diagnostic tester in some cases. 98% of spark plug threads are 14 mm by 1.25 same as your vehicle. Some of the newer chainsaw and trimmers use a 10 mm. ATV's can be 10, 12, 14 mm. Some of the real old equipment engines were 18 mm.
C cjdave Member Joined Apr 7, 2012 Threads 18 Messages 48 May 20, 2012 / Comperession Tester #4 Thanks that helps David
