oldlawnguy
- Jul 6, 2019
- Threads
- 7
- 118
I bought a Husqvarna Compact 23 for $20 - bar & chain are good, will rebuild Walbro WT-20 carb (diaphram is crunchy), fuel line/filter needs replacing (crumbled)
2 questions:
1. How do you access spark plug on this model which is on the side at an angle and located by muffler? I removed gas tank to rebuild, however can't figure out how to get at plug without taking rest of saw apart...
2. This model does not have primer bulb and only 1 fuel line from tank, so how does carburetor get primed on cold start? Little to no documentation available online as this is a 80s/90s era saw.
Nice little well built metal cased saw. Trying to bring it back to life
Thanks
2 questions:
Thanks
