Hook up a voltage gage and see what is happening when you lose power.
Voltage gauge? Connected to what specifically?
Thank you for your response BlazNT.....
Sorry for my wording. Something like this connected to battery. It will let you know what your voltage is running. I think it may be dropping out.
https://www.amazon.com/Waterproof-C...3639799&sr=8-6&keywords=amp+meter+usb+charger
I agree with Blaze on the voltage........ The electric clutch is using voltage the whole time the blades are in use and the electric pump is using voltage also .... The alternator is not keeping up more than likely..... A bad connection at the connector from the ALT or a bad battery if the ALT is working right ..........
That's my 25 cent piece since 2 cents ain't worth nothing anymore............
Let Us know Mon Ami ~!~!
