Tornadoman
- May 6, 2023
- 15
With this coming along with the change in the weather, I tend to agree with you that the grease in the Bendix has thickened. BUT... I had the same experience several years ago and discovered that the gear on the starter was plastic and had stripped.It’s just around freezing here and I decided to move my riding mower from the garage to the barn for winter storage. The battery is fine but when I turn the starter it just spins and doesn’t engage the flywheel. I assume the cold is causing the bendix gear to not rise, maybe from cold grease?
What are the chances the cautious use of a heat gun would let me get it started?
