The mower will crank and run fine. You can even mow with it as long as the kill wires are off the coils but won't shut off. But if the wires are on the coils it will not crank. It's a husqvarna model 128976. Serial #1C046G90210. 2006 yearWelcome
Just a little thing to start with.
We have nothing to work with but your words so the actual words you use are important
Crank = revolve
Start = goes bang a few times
Runs means it goes for long enough to start cutting grass.
You have a problem with the PTO Switch , the parking brake switch or the wiring between the switches and the coil .
Until you tell us exactly which Troy-Bilt mower you have this is as much information as I can give you.
We need the numbers off the tag under the seat128
Sorry about the wrong info. It's a Troy-Bilt model #17AA5ABP766. Serial# 1CO46G90210Numbers are not matching up. IF it is a Troy Bilt then it is not a Husqvarna and the serial does indicated it is a Troybilt (MTD made mower) with a 42 inch deck. Need the model number off the serial number tag or an image of the tag. Also need to know the model and type (spec) number of the engine.
Current either you have a safety switch problem or an engine electric problem.
I had the same problem, and I install a on/off switch under the seat. Put both kill wires on one side of the terminal and a ground on the other terminal.My troybilt will not crank with the 2 kill wires hooked to the coils. If I unhook them it cranks but won't shut off. What could be the problem?
Yes that will workI had the same problem, and I install a on/off switch under the seat. Put both kill wires on one side of the terminal and a ground on the other terminal.
