clutch rotation
gregjo1948
When buying a new electric clutch, how is clockwise or counterclockwise rotation determined? thanks, gregjo1948
Most engines rotate CW when view from the flywheel side.
This should help explain how to tell. But it might just confuse things too.
gregjo1948
That certainly confused me. My clutch has the pulley away from the engine. Does that mean I need a ccw clutch?
Basically you got to know which direction the PTO end of engine is rotating. Most rotate CCW when view from PTO end. If you are viewing the flywheel side the same engine would be rotating CW from that view but is still considered rotating CCW as clutch is concerned.
Besides if you got the old PTO clutch it will have the OEM make and model number (part number) on it normally. You use that to find a replacement clutch; unless, you just buy one from the OEM of the mower.
I just did a discuss on another forum that got my thinking straighter on this rotation aspect.
