H hmb39 Forum Newbie Joined Apr 24, 2015 Messages 1 Apr 24, 2015 #1 when clutch is engaged it is fine, when it is not engaged it rattles. Clutch is an aftermarket brand Extreme FatBoy. Anyone have any suggestions.
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,056 Apr 25, 2015 #2 the clutch has two bearings in it. The bearing that is inside the clutch part where the belt runs is going bad. When you engage the deck that bearing stops turning because it is now turning with the drive pulley.
