J jimbnew Forum Newbie Joined Sep 9, 2024 Messages 3 Sep 9, 2024 #1 2015, G5500. Let off the clutch and the engine dies. Press the clutch and it runs. What could be the problem?
ILENGINE Lawn Royalty Community Leader Joined May 6, 2010 Messages 12,060 Sep 9, 2024 #2 Most likely a seat switch issue. Does the same thing happen when you engage the deck.
J jimbnew Forum Newbie Joined Sep 9, 2024 Messages 3 Sep 10, 2024 #3 No. Just that. Could it be a safety switch somewhere under the clutch. If it is I have no idea where it is.
Hammermechanicman Lawn Addict Community Leader Joined Jan 10, 2020 Messages 4,052 Location Southwest ohio Sep 10, 2024 #4 If letting out the clutch kills the engine then that switch is working. Seat swith a better place to start.
J jimbnew Forum Newbie Joined Sep 9, 2024 Messages 3 Sep 10, 2024 #5 OK. Thanks. How do you check that?
