25 hp kawa
ok I've got the mower back together and it starts and run fine But
I think I have a bad diode in the clutch pigtail. I ordered a new one by
Hustler part no. The pigtail I received had the wrong connection config on the switch side.
My question is
Where is the diode? Is it on the connection to the clutch on on the connection to the switch side??
If it is on the clutch connection I can just clip the wires and use the old switch side connection.
Thanks for all the help so far!!
Joboy
My question is
Joboy
