clutch adjustment JD 212
hemmy711
looking for info on how to adjust the clutch on my 212. it doesnt fully disengage when the pedal is released, i have to pull back on the pedal with my toes, wondering if something needs to be lubed or a tensioner adjusted. thanks
Take a look at the spring.
Get a can of spray lube and spray every thing that moves.
And wd-40 is not lube.
