Clicking/crunching noise from rear wheel on a RWD mower
Take a close look at the plastic gear on the drive wheels. Willing to bet it has teeth which are worn away. Will need to replace the drive wheels. Before doing so take an even closer look at the bearing hoc, where the axle goes through. It may be worn, which will cause the gear wear and tear up new wheels if not corrected.
