double yellow
- Apr 19, 2023
- 70
Thanks good ideaLoad test battery, or remove it & take it to local parts store for FREE load test.
That would be a good idea Ford toughI'd remove the old solenoid, take it in to the local auto parts store and see if they could match up a starter solenoid from an older Ford car or truck. You'll never have to worry about it again. Or, you could put a cheapie replacement lawnmower part back on and be good for a few years, maybe.
I will check things out the next go around I haveWe don’t know if the solenoid or starter is the problem. Plus which starter he has, might be a starter mounted solenoid, where your suggestion won’t work. He needs to do some testing to isolate the problem and post back with all unit and engine numbers. DIY guys throw parts at units before finding the problem. Techs on this forum like to find the problem, then throw parts at it.
Battery test good, The starter gear is not going up to engauge the flywheel teeth at times. So i figured maybe the sol. was messing up. When i turn the key to start ]and keep trying to start it , it the starter gears springs up to the flywheel.If the starter is spinning, but not engaging, your solenoid is good. I wouldn’t replace it. You might not need a new starter, just need a replacement bendix kit. Please post all engine numbers and we’ll check to see if one is available. Dd you test battery voltage as I suggested in post #2? May be just a bad battery. I wouldn’t throw parts at it until I knew which component was causing the problem.
He said it was a twin cam Kohler Courage engine never seen a shift type solenoid starter on a Courage single cylinder engine. Probably the solenoid.Not if is an automotive style starter which are used on some Kohlers and Kawasaki.
