mechanic mark
- Jul 15, 2013
- Threads
- 175
- 7,381
Remove Blower Housing, top of engine & screen, & remove dirt & crud from cooling fins on each cylinder by hand using a piece of coat hanger wire etc. & I prefer using a Shop Vac instead of a blower nozzle spreading debris around engine. Harbor Freight has a pack of tools able to get into tight spots. You can also check your engine coil to flywheel air gap after cleaning is done. You will be truly amazed at the amount of dirt & debris on engine & how much better, cooler, your engine will run. Let us have some feedback on this one please, thanks, Mark
Hook & Pick Set, 6 Piece
Amazing deals on this Pick And Hook Set, 6Pc at Harbor Freight. Quality tools & low prices.
www.harborfreight.com
