Classic 2750/2015 year
RealAuct
Hoping someone can help me please. The Engine to deck belt broke, I ordered the replacement (double checked the #'s) Received and installed. It appears the belt is way to large, I cannot get any tension. The routing in the manual and on the machine are a little confusing but it appears I have it correct. Any suggestions are appreciated btw don't know and it shouldn't make any difference but it has the Generac motor.
Shows belt should be a 2010B85W. Belt is installed with flat idler to back of belt v idler to inside of belt.
Shows belt should be a 2010B85W. Belt is installed with flat idler to back of belt v idler to inside of belt.I did in fact order the 2021B85W Belt and the "replacement" sent was a 2010B99W. If the "85" & "99" are the length then I understand Thank you
Actually those are B belts so the 2010B85W is a 5/8" x 88". If you received a 2010B99W then you received a 5/8 x 102".
That sorta like me ordering a belt per the IPL for a Gravely and give a PN for a 60" deck instead of the 52" that the customer has in the shop. Arrrg; so frustrating with that happens as it cost more to return the incorrect belt then to just keep it for later use.
Thanks so very much!
