Chop saw carb prob.
upupandaway
I have a Husq 770 Where pour a little fuel into the carb and it runs for a second. I got a new carb and when disconnecting the fuel line, gas came out(so there is fuel pressure).
It just won't fire. I confirmed the 2 mix screws to 2 turns(from a Husq page recommedation). No go.
I thought it was a bad carb and got another one, but still same thing so I'm stumped.
I'm thinking there is no pulse?!?!?!? How do you suppose I test that??
did you go with a generic carb or the manufacturer's part? Does the behavior change when it is choked?
OEM. I pour in fuel and it runs for a second. With the original one, As I opened it past 2 turns, I did get it to run for a split second, but none more than 2 turns.
ps. Rivets, sorry. I forgot to take a pic. Will do tomorrow.
Does the carb have 3 lines on it? Main fuel inlet, primer return, and carb to primer suction? If so make sure they are all going to the correct place.
I don't own one but have had the 3 hose style on other engines that used a ZAMA type carb. Here is what Google AI says about hooking the 3 lines up on the K770. Beware that AI makes up stuff sometimes.
On the Husqvarna K770 concrete saw, the fuel line routing can get a bit tight underneath the air filter base and manifold housing. [1]
Here is exactly where each of the three lines connects on a K770 setup:
1. Main Fuel Inlet Line (Sucks Fuel to Engine)
  • Routing: Connects the fuel filter inside the tank to the main metal inlet nipple on the carburetor body.
  • How to trace it: This is the primary thick line coming straight out of the gas tank. Look closely at the Zama carburetor body—the main inlet is typically the larger brass/metal tube. If the saw runs but dies immediately or won’t start, this is the first line to verify. [1, 2]
2. Carburetor-to-Primer Suction Line
  • Routing: Connects the second, smaller nipple on the carburetor directly to the suction side of the remote primer bulb assembly.
  • How to trace it: On the remote primer bulb, the suction side is the shorter plastic nipple on the back of the bulb housing. This line acts as a bridge so that pressing the primer can draw air out of the carburetor's inner chambers. [1]
3. Tank Return / Purge Line
  • Routing: Connects from the discharge side of the remote primer bulb back into the gas tank.
  • How to trace it: On the remote primer bulb, look for the longer plastic nipple on the back. A fuel line attaches there and goes directly down into the gas tank through a second grommet hole. This line just dumps raw fuel back into the tank and does not have a filter attached to it. [1]
Quick Functional Check
Once you hook them up, press the primer bulb a few times. [1]
  • If routed correctly: The bulb will easily fill up with fuel and feel firm.
  • If lines are crossed: The bulb will either flatten out completely and stay stuck down, or you'll see air bubbles persistently blowing backward into your main fuel filter line. [1]
