Choke spring for Briggs and Stratton/ Mountfield quantum xm 35 where does it go??
james125
  • / Choke spring for Briggs and Stratton/ Mountfield quantum xm 35 where does it go??
I have a old-ish lawnmower that kept stalling, so I took the carburettor out and gave it a really good clean, it runs a lot better now. Though it only seems to run on the choke, it may be something to do with the spare spring I have. Any idea where it goes?
View of carb 1;
Veiw of carb 2;
View of carb with small choke spring on top (surrounded with red square)
Model 121882
Type 041901
Code 91120459
goat roper
Do you have the model and spec. # off the engine?
pugaltitude
You have the choke spring wrong way round.
The long straight part of spring should be on the choke shaft on carb and the spring side should connect to small hole on linkage that connects to shaft that pushes choke over.
