Tinkerer200
- Mar 14, 2015
- 913
There should be enough fuel in the carb bowl to start engine regardless of fuel pump. Choke plate should close completely. There is likely a couple of holes in the carb choke plate, I have blocked one of them to aid in starting IF linkage is closing choke butterfly properly.
I can send you a Service Manual IF you like, address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
Walt Conner
