Engine Chipper - Shedder
oldnacl
Just purchased a used chipper shredder 24A-424G766. Sat for a number of years, plastic still on portions. Had my John Deere dealer to replace carburetor, change oil, plugs, etc. runs good.
The engine is a 10HP B/S and look as new too. TroyBilt said it is a 2004 from serial number...Question is, there are two oil filler locations, one for engine and one, I assume for the shredder itself. I cannot find in operation manual if both ports use the same oil. That's my problem.
Thanks
OldNacl
Can you post either the engine number or pics of what you are talking about. Both would be helpful.
oldnacl
Neither the manual or pictures show this fill port. I found out from a gentleman on another forum the port is for liquid grease, and to use Benalene 920. Look up on the web, very expensive. Any thoughts?
OldNacl
