The only thing I hate about my heaters, is they have the thermostats on them, and it’s already 90 outside so they won’t kick on
I spent way to much time finding the problem of surging with a clone generator . It was new and returned to the store then went to a auction specializing in selling returns. It was bought , then problem was brought to me. I went through the carb 4 times , then ordered a new carb. It acted the same way with the new carb and gasket. I compared the new gasket and carb with the origial and it was same in every way. I noticed the gasket between the carb and intake was blocking a small round hole as was the original gasket . I used a hole punch and put a hole in the gasket put it back together. It was fixed and ran fine . Must have been a world wide problem for the new carb came with the same gasket.It's been a bad year for the off brand (Non Generac,Briggs, Honda etc) generators. or at least for me it has.
I've had several come in with issues and i finally have to throw in the towel, and more than a few are surging issues that i can't pin down.
I've got a DuroMax i'm working on now, my fresh gasoline, new fuel line, new carb from duromax, all new intake gaskets, surges for about 4 seconds on initial cold start, then goes away, begins to surge once i put about 3000 watts on it. unit idles down good. (10,500w rated). surge Goes away with choke, so i slightly oversized the main jet... i'm talking slightly... and it went too rich. had to swap the main jet from a junk duromax i have, same carburetor.
carb spray around the intake doesn't change anything so i know im sealed up good. Fuel flow stays consistent.
had a similar story with a champion several months back.
I've hooked my spark tester up and that stays consistent blue spark.
But i've not had a single issue repairing any Storm Responders or older powermates etc.... weird.
FYIIt’s their 13000EH (gasoline only) model 20Horsepower.
That’s the only identification on it other than the epa sticker
Not just on generators, but sometimes the hunting and surging on a small engine cannot be completely stopped. It absolutely drives me crazy. I end up spending way too much time trying to get it right and usually eat the labor time for customer.It's been a bad year for the off brand (Non Generac,Briggs, Honda etc) generators. or at least for me it has.
