Chewing gum in gas
Pmiketdc
Okay so I'm siphoning gas out of my Toro zero turn had a piece of gum in my mouth that I've been chewing for a little bit small piece Wrigley's anyways as I'm siphoning the gas the gum fell into the tank of zero turn what do I do what will happen I know it's ******** but it happened
bkeller500
After you remove the gas............can you attach a smaller plastic hose to your shop vac and fish the end of the hose into the tank and locate the gum?
