The code would only be read if the key is flicked on three times; on off on off then on and it will shoot your codes. I found that my 26 efi likes to go through oxygen sensors. I forget the exact number but you can cross them over to a chevy cavalier sensor and it plugs right in and the only reason i go through them is because of other injection issues and me gettign it wet when i take the engine out and clean it periodically. But check your codes you can go right online to finnd the fault codes. usually a 32 33 or 34 is an oxygen sensor code and after replacing the sensor it will fix your issues. The oxygen sensor completes the closed circuit that walker starter with its efi systems that are pretty nifty. But when things don't run right all the time, it will be your worst nightmare, get it fixed asap.
