Has anyone had any luck with cheap-ish compression testers, brands? I don't have any specific issues at the moment my motivation to get one is more educational and curiosity of how my gear is doing. So it doesn't need to be really good, but I also don't want to make costly repair decisions about my OPE based on a bad gauge. If it's luck as to whether they are accurate, can I use an air compressor to test the gauge, assuming that the gauge on my air compressor is accurate?
thanks in advance
LH
thanks in advance
LH
