Chasing no-crank problem - 1693695 Broadmoor, 17Hp Hydro And 44In
TheTango
  • / Chasing no-crank problem - 1693695 Broadmoor, 17Hp Hydro And 44In
Giving to a friend who just got his first house. But since last summer it won't turn over now.
All the lights indicate it should crank Neutral, Seat, PTO. Turn the key - nothing. Battery is good.
Been looking for a wiring diagram with no luck.
Any help or ideas?
mechanic mark
TheTango
Thanks for reply - I have checked the circuit breaker 12V thru and that seems good. Going to bench check starter solenoid today - not sure how to check the control module.
Will email Simplicity and see if they can supply wiring & electrical test sheets.
TheTango
Yhanks for the PDFs - today I am going to make jumpers for all the safety switches (take them out of the mix). Will report back if I have any luck.
BlazNT
Take them out of the mix one at a time incase one is broken. You will not have to backtrack to find it.
