ChargingSystem Opposed twin
Scrubcadet10
Staff member
Community Leader
Location
Conroe
Not charging.
12.6 volts at battery at all RPMS.
I have 1 red an 1 White alternator wires, the red one has 18 volts... And the white one only shows about 8-10 volts. and white connectors. The only double wire alternator my manual shows uses 1 red and 1 black wire...but I have red and white.
I looked in my repair manual, but it doesn't list my wire colors for some reason.
Briggs 42A707-2653-E1
Murray 46107x92a
Eureka!
right where the charging wires come out from underneath the shroud, Black and Red, and the red has a diode right before the connector, then it turns to a red wire and 1 White wire.
Did you have your Taryl teeth in when you had your eureka moment? ;)
