On my RZT50 with the Kawasaki 22HP engine (300 hrs.) the charging light came this weekend while I was mowing. It also shows "0" voltage on the LCD screen. I checked the battery. It shows 12.7 volts with the engine shut off. I get a 15 volt reading at the battery with the engine running. The 15 volts seems a little high but it tells me the charging system is working. The mower is running fine.
It appears to me the LCD digital display unit has a problem but I'm not sure. I would appreciate any thoughts on my opinion or personal experience stories with the same issue. Thanks in advance.
