Changing Transaxle Oil
Skippydiesel
Do the Forum members think there is any benefit in changing the hydrodrive/transmission oil on a Toro Wheel Horse 17 hp?
(FYI mower performs very well but in the past I have had a hydraulic transmission fail & have always wondered if a timely oil change might have extended its working life)
Should the consensus be, it would be beneficial to do this - any thoughts on best oil for the job?
I realise that this may require the transmission/transaxle being removed from the mower, as there does not seem to be any provision for draining the old oil.
Craftsman Garage
We need more information. Changing the fluid could either be beneficial or could reduce the life, but it depends. Age, brand, wear and condition, what do you use it for, etc. Its quite a bit of work for what it's worth.
Craftsman Garage
If its working great, I personally would leave it. When it starts going a little bit slower or starts Slipping, then change it 👍🏼. If it ain't broke, DON'T "fix" it 🙅🏼‍♂️. I've learned that the hard way lol, my curiosity kills me.😑
