Engine Changing oil in Craftsman Eager 1
bradcash
I have a Craftsman Eager 1 lawnmower that might be 30 yrs old. I need to know how much oil and what grade. Thanks for your help.
In your post two and two don't add up to four. Eager 1 has been around for thirty years, but the Tecumseh 6.75 engine didn't come out until about 15 years ago. The older Tecumseh engines used about 1 qt. of oil, but the newer ones used about 20 oz. You are going to have to figure out which engine you have.
dana a
About all 4 cycle push mowers use straight 30 weight oil. If it has a dip stick fill it to the full mark.If no dip stick pour the oil in till it is up to the top of the slot on the fill hole.
bradcash
I double checked. It is 30 yrs old. I married into it 14 yrs ago. I will figure 1 quart of 30W. Thanks a bunch. And I won't say 6.75 HP anymore.
dana a
It may not hold a whole quart of oil. If you haven't drained the oil you might note how much you take out but the easiest thing is to do like I said before. I'm going to make the assumption that a 30 year old mower doesn't have a dip stick but just a hole to pour the oil into. The hole has a slot part way up the hole probably just below the threads. The correct oil level should be up to the bottom of that slot.
