Changing Hydraulic Oil in Husqvarna IZ4818?
hitmanharleyk
How ofter do you guys recommend changing the hydraulic oil and filter on your zero turn mowers?
I have acquired the mower above and it has like 340 hours on it (less than 20 by me) and I got to wondering if it has ever been changed. Is the filter a special filter or just a regular oil filter that I can cross-reference?
ProLikeJesus
I asked my dad, and he said you never should have to change it, because it never runs out. Also, you change the filter if the hydraulic oil runs out.
Parkmower
I run a Husqvarna PZ 7234. It's the biggest ZT they make. It has a hydraulic resivouir and filter. I believe it recommends changing them at the 400-500hr range.
And I wouldn't use a oil filter. Get the numbers off the one that's on it and try a auto parts store. Or call a husq dealer.
KennyV
You don't change hydraulic oil because it may run out....
You change it because it will shear down Also it can become contaminated ...
Like Parkmower said use a hydraulic oil filter, it will allow the proper flow rate... KennyV
