Changed oil now hydraulics don't work
danformer
Changed oil on my hustler raptor 54 Kohler 24hp. Got done, now she won't move, and I mean zero hydraulics. Please any advice would help
sgkent
You need to remove the air from the tiny little pistons
It is called purging
Some times it happens in 5 minutes some times it takes all day
what is vitally important is the wheels must be off the ground so there is no load on the motor and the engine is running as slow as it will run
